FTView Refresher
Tweeker
Nov 2007
Smalltown
79
I am setting up alarms and the triggers. I want to use the bits of a DINT for my triggers. So, under the Triggers tab I have selected my DINT tag in the controller and selected the Trigger type as Bit. Under the Messages tab I have my alarm messages and the trigger selected. The users guide tells me that my value should be the "bit position". What exactly does this mean? Would the values then be 1,2,4,8,16,32...? Or would they be 1,2,3,4,5...?
It means that the FTV Alarms Server is monitoring the states and positions of the designated Alarm Trigger DINT components (32 BOOLs).
Align your ladder logic alarms generating code starting with the Alarm Trigger DINT Bit 0 OTE (then Bit 1 OTE, Bit 2 OTE, etc.)and then list the FTV Alarms editor Alarm Messages starting with a Value of 1 then 2, 3, 4, 5, etc....
It is slightly different than the old PView/PB32 Alarm Word Value setup.
Thank you. It seems I remember at one point where I had to change the trigger to a bit level under the messages tab.
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
189
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
240
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
102
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
99
