FTView Restore runtime problem
zaenalasiqi
Dec 2010
Indonesia
hi all,
i have a little problem with my factorytalk view application. i want to restore my runtime application using restore runtime application in application manager but in the middle of running there is message appear "unable to restore the the application, please check that:
-there is sufficient disk space
-the application is not open elsewhere
-the destination application does not already exist"
what can i do so i can restore my runtime application.
thank you
zaenal asiqi
give it a different name. I usally add a 1 or the letter A to the end of the original name.
I am assuming you are talking FTME and do you know what version it was originally created it? 5.0 and later are the only ones that allow restoring the runtime if that box is left check by default.
If it was created with a version earlier then 5.0 there is a backdoor work around that gets most of it.
Also, if you post it other maybe able to test the restore also.
Hope this helps
FTView - cannot restore .mer "file is not a valid runtime application file." Hello Experts, I was given a .mer file and i cannot restore it...
7,445
Hi all, How do you all do the backup/restore of the SCADA project? I have been using "HMI Server Backup and Restore", but now that process is...
1,623
Hello all, I have an old factorytalk view me HMI program that i need to edit. However all i have is the .mer and .med files. I managed to...
9,965
Having a problem restoring a .mer file. I can run the application in FTView ME but it won't let me restore the file to make changes. Getting...
1,455
I'm implementing several FTView 8.1 HMI applications for a client which are conversions from RSView32 & I've come across this wonderful...
1,756
