FTView Se - Auto open a Popup with an alarm trigger
saeqsae
Jul 2019
Concepcion
45
Hi all, i need some help with this little issue.
I wanna open a popup in any display when an alarm is triggered. I think this can be do it using the Events in FTV, but i don't know how to write the correct expression.
All suggestions are welcomed
see attached file
Hola Saeqsae:
This script is used to open several displays, but you can modified to open just one display (alarm display).
Just insert a numerical display in a cached display and when an alarm in generated move a number to the numeric display and open the desired display.
Thanks widelto, i going to try this.
Actually never worked with scripts before, so maybe this take me a time.
If you can give me a hand with this is always welcomed. Thanks again.
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
173
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
226
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
95
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
92
