FTView SE: Catch ‘item is unresolved in processor’ with VBA code.
Jan 2016
Kortrijk
I have VBA code on a FactorTalk View SE v11 project that reads various PLC tags in a FOR loop. All is good if the PLC tag exist.
But for a non-existing PLC tag, the “Tag Read” times-out. Via the “Tag Quality” the error is catched and moved on the next tag in the array.
The time-out time is long, ~20s, and therefore I want to stop reading this tag and directly go to the next tag in the array.
The “Tag Quality” updates only after the time-out, so does the Tag Property “LastErrorNumber”, “LastErrorString”. The “Err.Number” stays 0.
Yet in the FactoryTalk Diagnostic, the message “Item .. is unresolved in the processor …” is logged immediately.
How can I catch in VBA code this error and directly go to the next tag in the FOR loop ?
Thanks in advance.
VBA CODE
Code:
Private PLCTag() As Tag
For i = 1 To lngNumberOfParameters
   On Error Resume Next
    PLCTag(i).GetTagData Value, TimeStamp, Quality, SubStatus, Limit, True
    Select Case Quality
        Case 0:
            GoTo Skip
        Case Else
        End Select
Skip:
Next i
Thanks for the answer, but "On Error GoTo" works after the time-out.
Stopping the code by exiting the "subroutine" (exit sub), by a stop button is also only working after the time-out. Adding DoEvents statements isn't working either.
I know it's a late reply, but I ran into this same issue. After some (a lot) of tinkering, I think I found a solution (more of a workaround) using GetPropertyValue:
Code:
        If IsEmpty(PLCTag(i).GetPropertyValue(tagPropIdItemValue) then
            ' Tag is bad
            GoTo Skip
        Else
            ' Tag is good
        End If
    Skip:
    Next i
The tagPropIdItemValue constant for GetPropertyValue was the only one that I could find give me a different value for a good tag vs. a bad tag without having to wait for a timeout.
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
171
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
220
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
91
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
92
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
256
