FTView SE - Changing alarm severity on the fly.
Andy6
Apr 2011
In the garage.
140
I'm wondering if anybody knows a way to edit the severity of an alarm in FTView using a button or numeric input rather than going into the tag database. VBA possibly?
I have a customer that's looking at being able to change how Win911 dials out certain alarms, all 600 of them. (Win911 can change operation based on severity)
I have done similar things before using a numeric input on screen and compare instructions in the PLC. My problem this time is there are multiple PLCs from another vendor (which I'm not supposed to change) and 600 is just way too much work to add in a similar way.
Customer found what I believe to be a bug. I call a popup (On Top) display when an event happens. If they click off of the popup, it is still...
3,157
I've made a FTView SE Local Client with 2 displays. I want to change the displays every 30 seconds between each other. What is the best way of...
2,177
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
186
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
238
