Automated Changing Screens FTView SE
joelryan22
Aug 2017
Ohio
I've made a FTView SE Local Client with 2 displays. I want to change the displays every 30 seconds between each other. What is the best way of doing this?
I know this can be done very easily on ME using a few rungs of plc logic but how can it be done on SE?
i appreciate any help, thanks.
You can put a numeric display in the display. Assign a Tag from the plc. Then go to the VBA Code for that numeric display and unter NumericDisplay1_Change() you can (after proper error checking) call "ExecuteCommand "Display Screen_2". On your 2. screen do the same with ""ExecuteCommand "Display Screen_1".
Every time NumericDisplay1 changes in the PLC, the display will change.
Thanks! This is similar to what i ended up doing.
For the most part i was just struggling with VBA and how to read/write my tags from there but i have it figured out now(y)
Good. Yes, thats not so obvious and the FTV users guide isnt a help. Fortunately the is a site called plctalk with a handfull threads about that topic 🍻
Hello, I wanted to know if there is software that performs automatic backups and version checking. Additionally, it should support multiple...
497
I have been tasked with building an inventory of all of our automation devices across multiple large sites. Most of our hardware is Rockwell and...
17
2,421
Hi All. I Used this Post as a Starting Point to get the Files: http://www.plctalk.net/qanda/showthread.php?t=80472 I Then used FTP To grab...
883
Good Evening , Looking to upgrade and automate our motor rewind shop . I was on YouTube looking at some automated coil winders .Who are the...
1,196
New management team at my company is making a big push for automated reporting and OEE. They are also don't want to make any major capital...
2,120
