Alarm Log Files from PV+6 to Excel - Automated.
DwSoFt
Mar 2012
Alberta
960
Hi All.
I Used this Post as a Starting Point to get the Files:
http://www.plctalk.net/qanda/showthread.php?t=80472
I Then used FTP To grab the *.alm and *.mal files and Copy them over to a Control network PC automatically (Using WinSCP and scripting).
I Used this Link for setting up the FTP Portion:
https://theautomationblog.com/setup-and-use-the-panelview-plus-7-ftp-server/
What i would like to know is, Is it possible to Script the File Viewer Utility so it is automatic as well in converting to *.csv?
Operations wants to be able to view these logs easily.
I Have Quoted them an SE System but this is for the quicker solution in the meantime.
I Will see if i can find anything on TechConnect. Thanks.
In FTview ME V10 you can now export log files to different paths. The issue is that the documentation falls flat on assigning paths and how to...
4,112
Hello, I was wondering if there is a utility to view alarm log files from InTouch 7.1. I found that the system writes a new alarm log file...
5,668
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
279
Hello, I have a compact Logix plc and I have been task with configuring alarms into our SCADA when an Analog signal stops moving. The analog...
252
Hello, we have two PC with the FT SE local application and the same project. The one PC is wrong about alarm and event log. When I open the...
473
