FTView SE / FTAE Tag alarms
Mike_RH
Sep 2006
Toronto
896
Hey Gents & Ladies.
I have another question about FactoryTalk Alarms and Events Server.
On the dialog box when creating a tag based alarm, there is a check box "Show alarm as tag".
What does it do?
The online help and user manual are nicely vague. (no surprise there).
On the alarm status tab, if a I populate the field for In alarm tag, I get the same result whether the check box is checked or not. That is the In alarm tag is true when the alarm is active.
There is a warning in the help, don't turn on the show alarm as tag unless you have to, but that's about it.
So what does this feature do ? How do I make use of it? What is the performance penalty if I do?
All help appreciated.
Hi folks. I have a system that I'm working on that needs 2 alarms banners with different event subscription: - One banner for a specific area...
44
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
195
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
245
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
103
