FTView SE - Indirect Addressing
ASF
Jun 2012
Australia
3,921
Is it possible to display a value in FTView SE using indirect addressing?
For example, I have an array called String_Array of type STRING[10], and a DINT called Recipe_Pointer.
In Logix, I can use the expression String_Array[Recipe_Pointer] to get the contents of one element of that array, based on the value of Recipe_Pointer. Can I do something similar in FTView?
Ordinarily, I'd do the indirect addressing in the PLC and generate a "SCADA Display Tag" to be viewed in FTView SE. But in this application, the array and the pointer are in different PLC's. So I'll need to do something like:
{[PLC1]String_Array[{[PLC2]Recipe_Pointer}]}
I already have comms between the two PLC's so I can if necessary send the pointer from PLC2 to PLC1 and do it internally like normal. But I'm wondering if there's a neat way to do this in FTView without having to do that.
Ideas?
The only way I can think of is to build the tag dynamically in VBA, add it to a tag group, fetch it, and display it, but that has issues with updating the actual display.
That's roughly where I thought it would end up. If it's going to be that awkward I'll just send my pointer from PLC2 to PLC1 and have it do it's own indirect addressing internally.
Thanks!
Hi folks. I have a system that I'm working on that needs 2 alarms banners with different event subscription: - One banner for a specific area...
48
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
195
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
245
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
103
