FTView SE VBA - get tag value from parameter
ASF
Jun 2012
Australia
3,921
Hi all,
I've got a popup window in FTView SE which, when called, displays a string and an integer specified by the call parameters. i.e., I press a button, and it runs the command "Display popup_window /T string_tag, int_tag". Then in the popup, the string display connection tag is {#1} and the integer display connection tag is {#2}. That all works fine. But what I want to do is to get the value of whichever integer tag is being displayed, with VBA.
The code I have is:
Code:
Public MyTagGroup As TagGroup
Dim IntegerValue As Tag
Private Sub Display_AnimationStart()
If MyTagGroup Is Nothing Then
    Set MyTagGroup = Application.CreateTagGroup(Me.AreaName, 1000)
    Set IntegerValue = MyTagGroup.Add(Me.TagParameters.Item(2))
End If
But I get the VBA error "Invalid procedure call or argument" on the last line where I'm trying to set the IntegerValue tag to be that tag.
Can anyone give me a little more insight into what this error means in practice, or what the correct syntax should be?
Thanks!
I am running XLReporter (v14) and FTView SE (v11: Distributed Server) on the same computer (Server 2016 Standard). XLReporter is reading data from...
2,745
Hi there, I have been looking in the forums for this and I saw a couple of examples but I still don't understand very well how to create a VBA...
8,994
Hi I'm trying to do the simplest of readings. Read a memorytag in VBA and then show a display if the tag is set. However I get an errormessage...
2,170
Hi Guys, I am having some difficulty getting some VBA to work.My VBA is bad... I want to write a subroutine which takes 2 parameters 1. Value to...
5,690
Hi all, I have an FTView SE application where I'm trying to get one of the clients to display a popup when the PLC turns on a bit. My...
16,513
