gottspeed Member G Join Date Feb 2017 Location Canada Posts 24 Jun 8, 2022 #1 Does anybody know what's wrong with this syntax and why the time displays properly but the date doesn't?
plvlce Lifetime Supporting Member P Join Date May 2017 Location Michigan Posts 1,083 Jun 8, 2022 #2 Should be either SD for short date or LD for long date, just D is no good.
gottspeed Member OP G Join Date Feb 2017 Location Canada Posts 24 Jun 8, 2022 #3 plvlce said: Should be either SD for short date or LD for long date, just D is no good. Click to expand... That solved my problem, thank you very much. What should I be searching for in the manual to learn more about these elements?
plvlce Lifetime Supporting Member P Join Date May 2017 Location Michigan Posts 1,083 Jun 8, 2022 #4 gottspeed said: That solved my problem, thank you very much. What should I be searching for in the manual to learn more about these elements? Click to expand... I looked up the Use embedded variables chapter (page 397 specifically for time and date).
