FTView v11 (latest) but still invalid apa?
DwSoFt
Mar 2012
Alberta
960
Hi all.
I have read a bunch of posts on the forum over the years on the "invalid archive apa" problem, including http://www.plctalk.net/qanda/showthread.php?t=92132
I would always just update my version to the latest and life would be good again. in this case, a competitor made changes to a pv+ 700 (v5.0 firmware) button style display in november 2019, and left an apa.
it wont restore even with v11 and all the patches installed citing invalid archive, and the new me version utility also says invalid archive. the mer comes back as the proper firmware in the utility.
when i try the 7zip method it also fails saying its not a valid archive. i tested with older apa files and it worked successfully.
is there anything else i can try or am i up siht creek? im working on getting my rockwell account linked to our tech connect but currently i cannot read them yet.
I keep virtual machines with older revs of FT View. If you have that available you might give it a try.
I'd be happy to try to open your file if you'd like to PM me. I know if it is a customer file that might not be an option.
OG
Im thinking they may be corrupt, as 7zip wont open it or the mer file. I do not know the ME version, that is what i was trying to figure out.
Hi all.
Try to restore this with v6.1 using Windows 7 32 bit or Win XP virtual machine. After you do that create new archive file, take it to Win 64 bit machine and restore it with v.11. It should work. You will not need legacy tag database conversion if you do that. Note: It only works with v.6.1.
Hello everyone, I'm getting some weird behavior from one of my displays in a FTView SE v11 application which has a total of 10 displays. The...
2,308
Hi all, I'm installing FTView Studio ME v11 on a Virtual Machine. Using VMWare Workstation running Windows 10 (latest updates). The installation...
3,362
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
171
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
216
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
89
