FTView VBA Help
HCSDoug
Aug 2013
Here
In the past i have used Citect SCADA software, more specifically cicode, to log values to an excel spread sheet daily at midnight from an event.
is it possible to create VBA on a numeric input change to do the same?
I am not well versed in VBA and any help would be greatly appreciated.
Here is the Cicode that i have used in the past...
// Start of Function "Logfiles"
// This function saves information to the C:/Logfiles
// each day.
FUNCTION Logfiles()
FileName = "FLOW" + IntToStr(DateMonth(TimeCurrent())) + IntToStr(DateYear(TimeCurrent(),1));
MonthFile = "C:\LOGFILES\" + FileName + ".CSV";
IF FileExist(MonthFile) = 0 THEN
FileCode=FileOpen(MonthFile,"a");
FileString = "Date,Time,EFFLUENT DAILY FLOW, RUNNING FLOW TOTAL";
FileErr = FileWriteLn(FileCode, FileString);
FileClose(FileCode);
Sleep(1);
END;
FileString = Date() +","+Time()+","+RealToStr(EFF_FLOW_ACC_Daily/1,5,3)
+","+RealToStr(EFF_FLOW_ACC/1,5,3);
FileClose(FileCode)
I've been working on a fairly large project for the last couple months and have come to a road block for the last week. I've spent countless...
7,132
Dear Forum users i have a project, which i have to creat 2 recipe form with about 20 parameters in VBA form. - 1 recipe form used to fill...
4,179
I am using FTView SE 5.10 I am trying to access the value of a string display on a graphic from VBA code but cannot get it to work. Something...
5,626
Hi all. Currently I'm working on a VBa script for FTView. I would like to understand a bit better about some commands. 1) What are the...
607
Hi all. I'm running a VBA code on my FTView which is actually working, but everytime I open the display that calls the VBA code, it throws the...
28
1,835
