FTViewSE security
Lemming
Oct 2004
PalmerstonNorth
332
Hi, I don't normally use a lot of security with Scada projects as the PC's are usually in a secure location, and the end users don't want the phaffing about...
Current project is a bit different with a panel PC in the compound of a large plant, but outside with access for anybody
Using FTView SE, and have been playing with the security commands, and is not very user friendly ..
I want a default, view only account, and a couple of elevated privileges accounts.
On initial Project run, the user loaded is the Windows account. If I use the logout command, or set an autologout to time [x], I end up with a blank screen and login box only displayed.
Is there a way to mimic the RSView32 security functionality with a default user ??
Have done some more googling, and have added the idle detect activeX, and driving to dummy "Logged out" account... Sing out if there is a better way pls
That is how I do it.
You will still need to use VBA on a "Always On" screen running in the background to trigger the logout as you can't do it in a macro.
I am attempting to access HMI tag properties (Description, Minimum, Maximum values) to populate a numeric input. Is there a clean way to do this...
380
Hello everyone. I'm asking for help with the following problem: in FTView SE 13.00 for the AlarmEventSummary1 object, you need to add the filter...
605
Hi all, I've got a bit of a need to convert an integer (and a real in another situation) to a string with a particular format. This seems possible...
2,452
I want to have two displays that uses the same VBA variable "vbaint". But when I change between them, the variable seems to reset. How can I do...
2,820
I'm begginer at VBA. What should be the correct way to check if a display is currently showing and then show another display? I tried to put this...
17
8,400
