fuel system Micrologix 1400 HELP!!!!
annicat1
Mar 2013
Adelaide
Dear colleagues,
urgently need your help.
I need to add flip flop logic for pumps in my code.
Now the logic is:
We choose the tank and start pump 1 and if have fault or no flow then start pump 2.
If have no flow on pump 2 then start tank 2 and do the same checks (flow and fault for each pump). If have fault on both pumps then we dont start the other tank, just wait for reset.
I need to use this toggle bit in order to start the pump 1 when we have request first time and even if it works ok next time we have request we need to run pump number 2. We can stay with the same tank until it has more than 10%.
Highly appreciate your advice.
please refer the attachment example guide only,
you need revise/modified the drawing to meet your expectation,
as long its meet safety and process requirement,
if you request to us to check it may take time and effort,
the best you draw the logic flow to reduce the mistake anything to alter refer back the drawing.
your need decide your program whether complicated or standard,
draw the flow and translate to pulse/wave for first time,
if you professional programmer you will another technique/method.
I can put together what's going on with enough time but it would really help if you have a P&ID or sketch of the system.
Hi Gents I am working on a fuel storage and dispensing facility. Initally the storage part was being done by others, and I have completed the...
3,414
Hello, I am doing research project focused on the retrofit of a diesel locomotive into a hydrogen-fuel-cell-battery hybrid locomotive. The...
533
Hi, I am looking for a sensor to monitor the level of Diesel Fuel And Gasoline in an outdoor Storage tank. The Tank has cylindrical shape laying...
1,837
Greetings from all the way down here in New Zealand:-) I have a challenge for you all..... I have a need for a PLC to run a Doser pump to pump...
34
11,265
I am about to be upgrading several compressor engines to Logix 5000 and I am looking for the best, proven, ways to program in the various curves...
2,053
