JesperMP said:Hello MURDERER.
If the application has been made with "full screen" and "lock task switching", then you cannot exit from it or access any windows functions.
What I do in such cases is to program a special button that activates the Windows Task Manager. This button is then password protected.
If you cannot add such a button, then all you can do is turn off the PC !
JesperMP said:If you need to change an existing application from a panel to a PC, then use the Convert function.
JesperMP said:Set the Device Type to "PC". This will only be available if you have Protool Pro.
Sparkz said:If there's no 'button' already available in your current project to exit ProTool RT and you do not have ProTool/PRO to add an exit button yourself, I would suggest using CTRL-ALT-DEL and stop the ProTool RT application from the Windows Task Manager, rather than shutting down the PC. But this is pretty much all you can do...
