Function Block Timer Preset
DaleP
May 2007
Ann Arbor, MI
I am trying to set up a Function Block Timer (TONR in Controllogix5k) so that by changing the position of a selector switch, a different preset is loaded. With ladder logic I would just use two MOV instructions that would either move one number or another into the Preset, but the FBD timer doesn't allow me to "connect" the PRE input to more than one output. I tried this with MVMT and got errors. with only two choices, I can use Select, but what if I want more? Thanks.
use some variable to timer's input. With move/copy commands move new time to this variable.
If you want something like 3 different timer values, use three different move blocks and enable these move blocks with different bits/or with different integer value...?
Lare, if I understand you correctly, that won't work either. I can't Move or Copy to the same tag from two different instruction blocks. It's a bit like trying to drive the same analog input from two different transducers I suppose.
It appears that you posted a ladder logic program solution. I don't have a problem with doing it in ladder logic. I have a problem doing the same thing in Function Block Diagram (RSLogix5000). Please see attached. Red X's means RSLogix5000 is unhappy with my "overlapping data".
Ok, if you use third move block, this should work, because now you write only one time to timer_preset.
This also should be scalable = should work if you have 2 or 20 different presets for timer.
Anyway, I use different PLC platforms
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
126
Please see attached file. I need this program in Function Block form but I am totally lost on this. Any help would be appreciated. Thanks!
304
Hi! I am using a TM200CE40T PLC from Schneider to write data over Modbus. I have used Memory words (%MW) before using the Write variable...
542
Hi folks. New to the forum, but been working with PLCs for several years now. Would like some advice on whether you would keep this logic, or...
1,073
Hi Yes, I'm stuck again. Trying to define a Function Block. What I've put in there so far has been a straight copy/paste from the code (and that...
22
2,922
