Function block
irfan22in
Aug 2002
FRANCE
hi every body
Few days back i was working with a Contrologix PLC in an industry where i have to modify the code for my new project intergration with the existing one.
this existing PLC is programmed by some UK based compny and inthe program i saw the programmer metioning some NO and NC and OTE as function bolck out put and input.but what i coude see is the whole programm is written in the ladder logic .
but why this programmer is specifying the functon block output or input i did not understand.
is it ok to tell thatany bit if it is generated thru some parleel and series NO or NC contacts as Function block output or inputs.
hope to find naswer here
bye
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
Please see attached file. I need this program in Function Block form but I am totally lost on this. Any help would be appreciated. Thanks!
298
Hi! I am using a TM200CE40T PLC from Schneider to write data over Modbus. I have used Memory words (%MW) before using the Write variable...
537
Hi folks. New to the forum, but been working with PLCs for several years now. Would like some advice on whether you would keep this logic, or...
1,070
Hi Yes, I'm stuck again. Trying to define a Function Block. What I've put in there so far has been a straight copy/paste from the code (and that...
22
2,893
