fuse calculation for power supply
It really can't be calculated unless you know the power comsumtion of the componets inside but the rule of thumb that I use is.
If you have a 24v, 60 watt (2.5amp) power supply with a 120 volt primary.
60/2=30 watts or 2.5/2=1.25 Amp
Hope this helps
But if you really want to know read the lable on the Power Supply!!!
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
70
Hello, I have a question about fuses and how to calculate their required size. I understand that determining the appropriate fuse size isn't...
148
Hello everyone, What's the difference between nominal sensing distance and maximum sensing distance in a diffuse photoelectric sensor ? in...
1,123
What type of fuse is this ??? this one went pop It reads NEW & 5A (5 amp I assume) 2.4mm x 6.6mm I could not find any info on the interwebs...
2,653
Sorry about my newbie question. How to justify the OCPD price difference as shown in the picture below? Don't both adequately protect equipment?
3,354
