G.E Fanuc 90-30 Problem
student101
May 2016
karachi
Hi all,
I have facing problem in G.E fanuc 90-30 cpu IC693CPU232u .The problem is that during normal running of Plc all the led (Pwr, Ok and Run) are on but after some time Pwr led light remain on but the Ok and run led start blinking and then again stable.when the led start blink all the output of machine are stop.
I have checked the Fault Table.In Plc fault there is no error but in I/O fault Show loss of I/O module. I0.0 to I0.9.This problem is intermittent. Please guide me to solve this problem.
Hi, I'm trying to connect to a GE Fanuc Versamx PLC, P/No IC200CPU001, using either straight through 9-pin serial RS232 cable to port 1, or 9-pin...
6,508
Dear all, I'm facing a strange problem in genius bus communication.my system configuration is 90-30 hot redundant (software redundant) CPU372...
3,355
Any Suggestion for communication between three 90-70 GMR PLCs (15 - pin. RS-485 programming port) to SCADA PC . PC is not having serial port...
1,609
I have been trying to communicate with a inoperable GE Fanuc 90-30. Using Versapro 1.1 on a windows 7. Using a new usb converter cable #...
4,686
I am having an intermittent problem with a RJ3i controller. At a certain point in the program where the robot is ready to break a PLS scanner...
2,389
