GE Fanuc 90-70 PLC to PC communication problem
sranjeit
May 2016
Barmer
Any Suggestion for communication between three 90-70 GMR PLCs (15 - pin. RS-485 programming port) to SCADA PC . PC is not having serial port.
Distance between PLCs and PC is around 150 Meter.
Regards,
Ranjit
I suggest that you get an RS-485 to USB adapter for your PC and connect them per the 90-70 Multi-Drop serial communications directions found in the manual.
For the correct manual for this Communications you should contact CEMTEC who are the current owners of the 90-70 PLC.
Or search the GE Knowledge site.
Everything was working correctly until after a power cycle. The Fanuc robot EIP settings are no longer RUNNING, and are only ONLINE. It can't...
3,954
HELLO ALL !!! I want to control three VersaMAx IC200UAL006 PLC on Modbus communication. One is the master PLC and the other two is the Slave PLC...
20
10,585
Hi Dear friends,i need a communication cable for GE FANUC 90-30 series plc,power supply is IC693PWR321 and IC693CPU313x is CPU(5 slots base...
5,620
Hi everyone, I have a Fanuc CPU 331 series 90-30 and some IN-OUT modules mounted in a 10 slot base-plate. It's an old PLC from the 90's that is...
8,830
Hi, all gentlemen Before, our plant use GE FANUC CPU350, only one port on the PS mould can connect to laptop. But now we change to CPU363, both...
12,915
