G306A HMI Blinking
Red lion g306a blinking
I'm not sure if every page is blinking but I do know that the main page is blinking. When you go to the alarm viewer and clear the alarms then the blinking stops. Thank you for responding.
I've used alarms quite a bit on the G3 but I've never seen the behavior you're describing. Maybe because I always use automatic accept. Is the whole page flashing or just a certain object?
There are number of possibilities. The fill color of the page could be set to change continually if alarms are present. Or maybe there is a big object stretched across the whole page that does the same thing. If this is a program you wrote, you could probably confirm or deny these ideas. As far as I know, there is isn't a simple option you can turn on to make the page flash during an alarm condition.
Check your alarm set up. There is a box you can check to have the HMI play an alarm sound. I think the screen blinks too. Your speaker may not be working so you don't hear the sound but see the screen blink.
Had that happen once and the customer freaked out. Thought the screen was going nut's.
"The Siren property is used to indicate whether or not the activation of this alarm should also activate the target device’s sounder. While the sounder is active, the panel’s display will also flash to better draw attention to the alarm condition."
Looking for some help on the red lion side I was able to diver out all the port settings to get the hmi to talk to elc having the are-485 light to...
1,115
Good Day Everyone! We have a project the requires an encoder connected to a Paxi Meter and then into the HMI in order to display/record depth and...
3,177
Anyone done this and can save us some time? Implemented a Red Lion G306A HMI to a Numatics Valve Stack Communications Module w/Modbus TCP/IP or...
4,484
Trying to get a G306A panel to talk to an SDM120CTM meter but i can't make the Red Lion make sense of the response from the meter. Using PC...
885
Hello, i am new to both the redlion g306A and the Emerson FX-4120. Currently we have a T-21 Data Entry Panel hooked to the Drive. its only...
1,076
