G310 Floating point to SLC 5/05
allscott
Jul 2004
1,332
I am working on my first G310 project where I am connected to a slc 5/05 with ethernet and using DF1 Master.
All of my communication appears to be working except for my floating point values. When I enter a value of 100 (F8:16 in this case) into the HMI I get 2.45.....e-42 in the PLC?
Did I miss something?
See if this pic helps.
I am using a 5/04 through a NET-ENI on this channel with the driver "Allen-Bradley DF1 Master via PCCC/EIP".
It might be that you didn't specify to treat the tag as a float...or did something different with the scaling.
check that you selected Floating point in your HMI. If you are using Crimsion 3 numberic tags come up as Signed Intergers by default.
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,127
Is it possible to print a file from a Red Lion G310 HMI to a networked printer over ethernet?
1,287
Hi. We are currently experiencing slow loading or response time on our Red Lion G310, at about 5-10 seconds delay once we press a button or even...
1,626
Hi All, I have a current system with a Red Lion G310 Graphite screen (HMI-1) connected via Ethernet to a CompactLogix L33E. I have been...
1,571
This is my first time using these two, and I have picked it up fairly well. I don't have much programming experience(very, very little), but I...
1,638
