You should have started a new thread instead of hijacking this one.
That manual will not help for your problem. Go to www.heap.com and get the manual for your Horner module.
You need to update your software to Proficy ME.
Russ, You are right.
I thought about the "hijacking" aspect, but felt that the opening line revealed my intentions. That is, If something didn't appear in this thread, (and it seems the problem is found) then I have to embark on my own path. i.e., another thread.
I just didn't want to have two threads repeating a topic if one would do the job. ;-) But on your input, I have!
And Yes, I have the Horner User Manual open.I looked at the literature prior to procurring the card, and now that it has arrived, I used it to set up the card in the last available slot on the plc.
Brilliant eh!
The config change verified without complaint.
That manual refers the reader to the GFK0582 literature.
And so, around it goes!
If I knew which bits of information were vital, I'm sure I would be on my way.
How would Proficy help? The Horner literature indicates using the LM90 dialer. for the phone connection. The hardware and software seem to be speaking the same language. Perhaps with the aid of an ear horn due to the declining ability to take in information with advancing age.
Does the Proficy software offer advanced legacy support? (oxymoron ;-)
My continued appreciation for the support!
Cal
