jets
I have read a few threads here at plctalk on the GE State Logic Processor, an IC693CSE313B in my case.
I have the Eclips software V3.01 but one of the disks are damaged, I also have the hardware key. I was given a newer copy of the software but I sill cannot open the project in the PLC as I don't have the password or the original project.
I think I am going to opt to replace the CPU with a standard CPU like the IC393CPU311 and start over. I have a fully licensed copy of Machine Edition.
The way I understand the Ecplis package is that it was the programing software and the operator interface through the DOS PC program.
The machine has a single axis controller IC693APU301 and a slot each of Input and Output.
I think I will have to add an HMI for operator input but the CPU313 only has one COM port a far as I know. It's been quite a while (2004) since I have done a GE with a HMI and PLC. I forget how do you communicate with the PLC and the HMI, do you have to keep switching cables back an forth or use a PC with two COM ports? What are the communication option on the CPU313, does it have RS485?
Well I will start there next we will figure out what HMI communication I could use.
Thanks, jets:site:
Thanks, jets:site:
