GE 90-30 to Panelmate 1000
Sneal
Jun 2022
Hattiesburg, MS
I recently converted a lm90 program to proficy by using the import feature on proficy. The program seems to have converted correctly and can download with no errors. However, I have lost all communication with the Panelmate 1000 hmi. The panelmate is connected to the plc's power supply using a 15 pin to 9 pin rs-232 cable. I have verified that the cpu baud rate matches the panelmates baud rate. What could I have missed while converting this program? Any help would be greatly appreciated!
The PanelMate 1000 probably requires an SNP ID in the PLC. The conversion from LM90 to PME may have blanked that field in the CPU configuration. Be aware that an SNP ID of zero is not the same thing as a blank SNP ID.
Another possibility is that PanelMate's SNP driver defaulted to a parity setting of "None", while the PLC's default value is "Odd".
Thanks!
I looked in the cpu configuration and there is no data entered for the snp id. I then checked another machines program that had been converted a couple of years back and it had 1 entered for the snp id. I tried a 1 and had no luck. Do you know how I could find out what should be entered there?
Hello everyone, I was wondering if anyoone knows how to change the contrast on a Modicon panelmate 1000. I do not have the software for the unit...
1,859
Any body can guide me how to do communication between Modicone Panelmate+ 1000 and Modicon Tsx 984-255 ?
1,985
Hi everybody, if someone have the software for panelmate 1000? I search on the web site of Cutler-Hammer, and i don't find it. Please help me.
15,838
S
I'm searching the configuration software for a Panelmate 1000. I have to do one little modification in an operator interface Cutler-Hammer...
8,049
Good morning, i have a problem with panelmate 5000 pp. unfortunately I pressed the 3rd and 5th keys while booting the Panel. Now , the alternate...
514
