Put in fresh battery...same issue.
This time I uploaded what was in it before downloading....
It was the old logic and configuration (done by someone else) I had upgraded over a year ago!
The upgrade involved removing a Comm module from slot 0.2 and reprogramming the ALG222 module in slot 0.4 (this explains those faults), also fully new "standardized" logic.
So I cleared the memory and downloaded again including updating flash memory. But flash had an error again...this time I looked up the error. It was that I did not have "privileged rights" to flash. This means the key has to be OFF to write to flash...learn something new every day. I assumed that having the key "Disabled" in the CPU meant it was not doing anything....doh. CPU was also set up to use RAM.
So with the key off, I downloaded the cleared memory to the PLC logic and Flash.
Then downloaded my logic and to flash. everything went in no issue.
after 3 times of shutting down and restarting to verify...it came up great every time.
Eureka!!
Now....what function does the key actually perform on a 372 CPU?
When does the CPU actually load from flash when the CPU is set to use RAM?
Eureka!!
