GE ALG390 Output basic usage
SouthPahw
Mar 2011
Heartland U.S.A.
25
I am trying to use this card, IC693ALG390 to send -10 to +10 to a proportional valve. Am having problems setting up logic...could use help. Card is configured, %AQ0001 but not sure about where to start. Have been thru GE manuals and multiple posts and trying different things. I have Logic Master ver.9 and/or Cimplicity, PLC is 9030.
Here's a program for kettle control I had on a flash stick. There are some AQ usage in there. The File should cimplicity machine Edition.
Maybe you can get some ideas from that. I don't ME here at home so I couldn't the open file. I also have programs in LogicMaster if you want. I do have a copy of that.
edit: To large to attach
Would it be possible for you to creat a new program from your one in logicmaster and only include the relavent data to the Analog Output area? I can use/view either. Thanks!
Just wanted to let you both know, I was having a brain freeze and missing the simplicity of it. But Thanks for the help, the lights came on and got it all together.
Hi There, I have a filler with a coriolis flowmeter that has died. the filler requires a pulsed output (manufacturer wont edit the program) is...
256
Hey all, I am starting a new project for a customer and I am adding in solenoid valves. Once added, I noticed there was a lack of an Output...
89
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
191
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
127
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
341
