GE CIMPLICITY project appears empty in Workbench
AMill
Apr 2019
Colorado
I'm working on some upgrades on a CIMPLICITY system. I have a project folder which includes a .gef. When I open the project in workbench it looks like nothing is there - no screens, no points, no alarms.
I know this project isn't actually empty because I can see the screens in the project folder. I've been playing with the lock files and hitting the Configuration Update button, but I can't seem to build the project. I also ran a Point Xreference which showed me where the points were mapped to the screens - I just can't see the points or screens in workbench.
I'm running CIMPLICITY 8.2 (correct version and build) on a windows 7 VM if that helps.
What am I missing?
Did you stop the project before making a copy of the file? If not some of the objects are in use and won't be copied.
I had a coworker open the project without issue, so it seems like all the objects got copied correctly.
I reinstalled CIMPLICITY and the problem seems to be resolved. Still confused what the issue was in the first place. 🔨
Hello all, Sysadmin here in the process of deprecating an admin account and creating a new one. As part of that I was testing to make sure that I...
2,419
I have just set up Cimplicity 8.1 after not having used it in a while. No matter what project I have, that I try to open, when the Welcome Screen...
1,422
Hi all Please Can any one help me to get any simple project to the program Cimplicity hmi Greetings to all
1,566
Hi friends; I install version 4.01 and registered but when i open workbench and start to new project it is grayed out i mean disable. is there any...
2,718
Friends I have the version 4.01 when i open the project a popup window opens project create in newer version can not open in it. how i know that...
3,819
