Open the project in cimplicity
jcp
Feb 2010
Multan
369
Friends
I have the version 4.01 when i open the project a popup window opens project create in newer version can not open in it.
how i know that the project made in which version? and can i upgrade the version without autherization code?
Best regards
Cimplicity version 4.01 is at least ten years old. You will probably find that there are not too many existing projects that you can open with it.
Your best opportunity for the current version as well as for training is your local representative who sells the product.
To identify the version used to create a particular project, open the project's .gef file with notepad. The first line of the file will be "[Version Info]" The next line will identify the version and the build number. For example, "Version=7 0 9039" means version 7.0, Build 9039.
And before you ask, no, you can't simply change that line in the .gef file and expect version 4.01 to open a project created with a newer version.
Hello all, Sysadmin here in the process of deprecating an admin account and creating a new one. As part of that I was testing to make sure that I...
2,421
Hello! Any one please advise me how to open the GE cimplicity project created by V8.0 with V6.0 software, as I only have cimplicity V6.0...
3,669
Hi guys, I am looking for some help with using GP-PRO to open a project file. Every time I try to open my project file, I receive a message...
506
Hi, Im trying to open an old old Siemens WinCC project. It doesnt have to run i just want to look at the project in WinCC explorer. Its...
699
Hi, I received the following project from a customer on a QuickPanel Proface 6" that I need to swap to a Siemens Panel. However, I cannot seem to...
350
