Ge Fanuc 90-30, Beijer HMI E1101.
zaloultra
Feb 2014
harstad
Hello! I am trying to get my setup to work but i have come across a problem! i cannot get the HMI to "write" i/o to the plc(like start buttons and so on). but the HMI can read i/o's from the PLC(like a start light and so on). i am wondering if im doing something wrong with the addressing or something?
setup:
Ge Fanuc 90-30, 331 CPU.
Beijer HMI E1101.
RS232 from HMI to the 90-30 powersupply using SNPx protocol.
i also programmed the plc to output from one of the OUTPUTS when the SNPx protocol reads and one for write. and when i click buttons on the hmi one of the OUTPUT light flashes, but nothing happends.
i addressed the start light/symbol in the HMI to "snp id":%O2
the address in the plc is %O00002
This works.
i addressed the start button in the HMI to "snp ip":%I3
the address in the plc is %I00003
This does not work.
AAAAAh. I was sure i tried that but yeh that worked(might have done something wrong when i addressed the %M the first time)!
But thanks anyway!
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
40
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
125
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
117
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
109
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
181
