GE Fanuc 90-30 Losing Changes
ngilbert
Oct 2017
Ohio
28
We have a machine using a GE Fanuc 90-30 IC693CPU363 and we made a few changes to the program and it seems when we check on the machine again it loses the changes we have made and reverts back to the previous state. The battery light is not on. Just curious if I was missing something simple.
Check the hardware configuration to see if it is set to load the program from flash memory on power-up. If it is, and you want to keep it that way, make sure you save any changes you make to flash memory as well as to RAM. You will need to stop the PLC to save to flash memory.
Are you making changes to the ladder logic or just changing data values?
Just making changes to the ladder. The parts counter on the HMI counts how many time the tapper runs but we have some parts now that don't need tapped so we changed it to count how many times the nailer runs.
when you go to download the program you'll see a little check box for "write to flash memory", make sure that's checked when you do your download
We have a GE Fanuc 90-30 that will lose it's program after weekend shut down. This has happened a few times and we changed the battery last week...
2,339
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
117
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
114
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
107
