Ge-Fanuc 90-30 plc
bibhuti2050
Jun 2016
jajpur, odisha
Will you plz suggest me for the following problems.
We are using Ge-Fanuc 90-30 plc in our plant and we have proficy machine edition 6.5. we have two remote I/O(RIO). The rios consisting of PS, NIU and I/O cards. When I am connecting the laptop(with proficy machine edition installed) via cable IC200CBL002 And one serial port converter with the NIU, And try to go online with the target, it is unable to go online. Message is coming: Time out(after 10 attempts).
Pls suggest me what are the problems may be with us.
Thanking you
What NIU are you using? I have only been able to get online with a Genius NIU using a laptop with a real serial port. None of the USB/serial converters I have tried have worked even though they work fine with the PLC.
I believe this is true of any of the NIUs however you may want to try the latest firmware for yours.
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,097
Dear Everyone I work with PLC GE-Fanuc. But I don't know that "PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming while...
3,088
Our PLC output 7 opens a valve to move a cylinder rod. The output turns on every minute. The output is supposed to be ON for 10.56 seconds. But...
2,919
Need to find where to get VersaPro or Proficy software for the GE Fanuc 90-30 PLC.
2,550
Good afternoon all, hope everyone is doing well. Could someone explain the pic attached on the wrt.not instruction? To me, it looks the same as...
2,131
