GE Fanuc 90/30 programming cable
I doubt that an earlier version of LM90 will help.
Are you using a USB/serial converter? Make sure that the COM port it uses matches the one Logicmaster is set to use. Personally I have had mixed results trying to use Logicmaster through a USB/serial converter. I prefer an RS232/RS485 converter.
I have never been able to get one to work... and have had a few of the USB returned and exchanged for the serial version when they had older PC's and running LM90
Hi All,
Thanks very much for your help. I need an older version for logic master90.
I have v 9.5 and cannot go online with 331 cpu
Best Regards
Check your cable and serial port adress, it's work with LM90 and Proficy. If you use usb/serial converter make sure it's good one.
And I have used that cheater cable since about 1990 when the Series 90 PLC was born. That on nearly every type SNP port GE (GE FANUC) ever supplied and every style and version of programming software available. :p Although I have rarely needed or used a USB to Serial adaptor.
But then some say I'm luckier than most. :geek:
I say that I have been Blessed!
Hi All,
Best Regards
You would only need an older version of LM90 if the CPU331 is older than about version 4 and then in most cases it will still connect and upload but not download. If needed I can look that up to get an exact ruling, let us know.
Try this:
Note that it is not approved by GE Fanuc.
9 pin-F 15 pin-M
Rd 2 --------------- 12 SD+(B)
Td 3 --------------- 10 RD+(B')
Sig.Gnd. 5 ---------------- 7 SG
RTS 7 ---| |--- 6 RTS+(B)
CTS 8 ---| |--- 15 CTS+(B')
DTR 4 ---| |--- 8 CTS-(A')
DSR 6 ---| |--- 14 RTS-(A)
Hi Steve,
Does it have any effect for PLC hardware, PC' COM port and programming inside PLC when we use this "cheater" cable?
Thank so much.
Our PLC output 7 opens a valve to move a cylinder rod. The output turns on every minute. The output is supposed to be ON for 10.56 seconds. But...
2,892
Hey Guys, I have plenty of experience with AB plcs . What is a good starting point to learn about fanuc robot programming. How to get started? Is...
2,710
Good afternoon all, hope everyone is doing well. Could someone explain the pic attached on the wrt.not instruction? To me, it looks the same as...
2,116
Hello Everyone, I would like to get some advice from seniors!! Currently, I involve in writing PLC logic and Robot programs (ABB rapid...
3,904
Hi Guys, I'm looking for someone who might still have software that can open a program from and old 90-30 PLC. We have just taken on a new...
34
23,276
