GE Fanuc 90-30 with MaxOn
Rogelio
Jul 2013
Texas
24
I transferred to one of our plants that still has several 90-30 plcs after the previous programmer retired. I have been asked to edit a system that is running a MaxOn redundant project while the PLC is still running. I cannot stop it.
I have only a few months of self taught experience.
My question is, can I edit one PLC at a time and not stop the process? can this be done online?
I am not sure what version of software was used to produce this project but I believe it was VersaPro. I also have Proficy 7.0 ME and 9.0 ME.
I have the projects, 2 config and 1 logic.
What would the process be to accomplish this?
Thanks for any help.
Roy
Still waiting for GE to approve my login account.
Have you done this Steve?
Can I edit the standby processor, then transfer to it and then load the logic only into the other processor?
Roy
When I try to load the project into a test PLC on the bench, it fails with an error about
%R memory usage exceeds limits in HBR_010. using VersaPro 2.02 2214
I have only ever encountered one Max-On system and I did not have to modify it. I would be surprised if you could not edit the CPUs without shutting down the system. That is whole point of redundancy after all.
I don't know if the error you're seeing is due to Max-On or to the configuration of your CPU. Different CPU models have different %R memory sizes. You can also reconfigure the %R memory size in some models. That's the first place I would look.
Just a heads up, every Maxon 90/30 application i've ever encountered has been password protected. I've never been able to track down the password. Your experience may differ though.
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
115
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
114
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
107
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
174
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
222
