GE Fanuc 90-30
hokhoa
Oct 2011
ptown
I've a GE Fanuc 90-30 with CPU331.
All LED is on, but when I try to connect/plug my computer to the RS485 port the "OK" and "RUN" turns off, then Im not able to go online.
The same happens when the program set multiple outputs, OK" and "RUN" turns off. I need to power recycle to get the PLC back in RUN mode.
Is the Power module defective or the CPU, or other modules?
Are there any entries in either the PLC or I/O fault tables? A failed output module might produce your symptoms. A failed power supply could also. Try removing all of the I/O modules from the rack. I the CPU can run its program properly with no I/O, then add the modules one at a time until the problem reappears. Then try with only the module that caused it to show the problem. If you can make the problem happen with only one module, replace that module first. If the problem only happens with some number of modules in place, replace the power supply first.
I'm not able to go online, when I connect the cable the PLC stops, no Ok or RUN LED. So I can not see the I/O fault table. Immediately when I connect the cable the PLC stops.
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
37
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
122
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
116
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
109
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
179
