GE Fanuc 90 30
As A_G noted, the first thing you need to do is read the floppy to see what programming software was used to create the backup. Logicmaster used a utility called PKZIP which created a number of files with extensions, PK0, PKR, PKA, etc. Versa Pro creates a .bak backup. PME creates a .zip file.
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
37
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
123
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
116
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
109
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
180
