GE Fanuc Controllers: Symbolic Memory
kdcui
Dec 2007
USA
386
I am using a GE PAC RX3i with Proficy Machine Edition. I'm using iFIX to design the HMI/SCADA interface.
I have been mapping memory to the user space memory (%M, %I, %R, etc...) and iFIX has been able to see these variables fine (as long as I publish them as "External"). I am wondering if I do the same with symbolic variables (not assigned a %[M, R, etc...] user space variable), should iFIX still be able to see it? The "External" option still appears in the symbolic variable properties, so I think it would be able to.
EDIT: Further inspection indicates that this symbolic memory is located in %W, which apparently is still separate from the rest of the assigned memory.
If you have the current iFix version, you can access the Symbolic variables by name only, you need not use the %W, but you may. Quite versatil actually.
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
51
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
133
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
125
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
119
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
191
