GE Fanuc Modbus Memory Areas
paulowen1
Jan 2004
I have a Honeywell DCS as a Modbus Master polling a GE Fanuc 90-70 PLC. I need to know what the Modbus address corresponds to the Memory area in our 90-70 PLC.
e.g Modbus 34008 is this reading from %AQ or %AI ???
Modbus 17001 is this reading from %Q or %I ???
Modbus 06001 is this reading from %M ????
Modbus 43001 is this reading from %R ????
Please could some help me!!
many thanks
Paul
Modbus 0xxxx corresponds to %Q ouputs. Modbus 1xxxx corresponds to %I inuts. Modbus 4xxxx corresponds to %R registers. Modbus 3xxxx corresponds to %AI analog inputs. %M memory in the 9070 is not directly accessible via Modbus commands.
Hello everybody, I want to communicate with two PLCs (PC1: GE Fanuc: proficy machine edition which runs under quick panel IC754C & PLC2: Microlgix...
18
5,063
Good Day, I am Experimenting with Some more Modbus had had a few questions Regarding the Rx3i and Modbus. I have a big solar project At My home...
2,229
Dear Sir, I have GE Fanuc PLC CPU350 and CMM311 module. 1. CMM module configured as RTU only 2. Connected CMM module(Pins 2, 3, 7) to PC usng...
2,054
Hello all: This is my first time doing a MODBUS communication with GE Fanuc 90-30. I am using CPU 360 and a 10 slot rack with a lot of IO's. At...
5,042
Ill try to make this simple. How would i write a 0 into register 3051 in a Modbus Device. and a 1 into 3012. I have astablished Communications...
4,115
