GE fanuc plc trip
mkp
Jul 2018
pataia
hi
I have system control with ge fanuc plc, the cpu is CGR772 and cpu connect to i/o with GBC and NIU.
GBC: BEM713
NIU: IC200GBI001
I/O CARD: IC200ALG240 (Analog input cart)
Power I/O cards: ic200pwr002
my system control is working, but in some days PLC read zero from some channels analoge input card and then PLC Triped and all system control Droped doewned. when i reset power of I/O cards the system again workinig.
analog input card config: span low=4000,span high=20000, default=0
why PLC read zero from analog input card?
thanks for your help.
The default = 0 option means that when the CPU loses communication with the I/O modules on the drop, the analog signal is driven to zero. The alternative is to hold the last value before the communications loss.
What kind of entries are you seeing in the I/O fault tables?
Hi
I received "Low Alarm", "Low input", in I/O fault table.
may be this problem cause of card hang up? or just default=0 in I/O config is cause of this problem?
my default in I/O config: "default=0"
And
"%AI default/Hold last state"= default
can you help me how can i solve this problem and what changes need to do?
thanks.
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,082
Dear Everyone I work with PLC GE-Fanuc. But I don't know that "PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming while...
3,075
Our PLC output 7 opens a valve to move a cylinder rod. The output turns on every minute. The output is supposed to be ON for 10.56 seconds. But...
2,906
Need to find where to get VersaPro or Proficy software for the GE Fanuc 90-30 PLC.
2,544
Good afternoon all, hope everyone is doing well. Could someone explain the pic attached on the wrt.not instruction? To me, it looks the same as...
2,120
