GE Fanuc PLC with high speed data acquisition?
busarider29
Aug 2013
Midland, MI
399
We are exploring options for high speed data acquisition. Currently use AB hardware to do the machine controls and then NI hardware for the high speed (>= 1 kHz) data acquisition portion with load cells, thermocouples, speed sensors plugged into the NI hardware to collect the high speed data. Does Fanuc offer any solutions with their PLC's that would allow elimination of separate hardware, in our case the NI hardware, to do both the machine controls side (PLC) and the high speed data acquisition side?
Fast Data collection.
Not GE Fanuc but GE_IP does.
Using a PAC controller with a Refelctive Memory module to a PC running Historian is about as fast as it gets for off the shelf hardware/software today.
The speed needed will determine which platform is needed, either RX3i or RX7i.
You can ask for someone to come in and talk from here:
http://www.ge-ip.com/products/pac-programmable-controllers/c547
This might be the ticket! Been searching all over for something like this and just didn't think it was available in a single PLC unit. If its fast enough on sampling data and kicking it out, say 1 kHz range give or take, then this could be the guy. Thanks!
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,048
Dear Everyone I work with PLC GE-Fanuc. But I don't know that "PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming while...
3,050
Our PLC output 7 opens a valve to move a cylinder rod. The output turns on every minute. The output is supposed to be ON for 10.56 seconds. But...
2,888
Need to find where to get VersaPro or Proficy software for the GE Fanuc 90-30 PLC.
2,538
Good afternoon all, hope everyone is doing well. Could someone explain the pic attached on the wrt.not instruction? To me, it looks the same as...
2,113
