Ge fanuc snp-x / nematron hmi
anthony tony
Jun 2012
Tennessee
I have a question concerning communication between a GE FANUC SNP-X and a NEMATRON 8104XH HMI. I keep getting a 'PLC NO RESPONSE" error on the HMI. I've double checked the HMI program for wrong address and the plc address, I've even called the manufacture of both items with no luck. The communication cable was wired wrong but has been changed to the correct configuration with same results. The HMI communication led is flashing as tho it has connected but still gives error. I did notice that the CPU light on the HMI is not on, but the tech support said that was ok. Any ideas?
Post your cable pin-out here and triple check that ALL software/hardware parameters are identical at each end. Are you sure that this unit needs an ID for the slave, if set for 'Direct' it will not.
Hi Folks, especially anyone who remembers the GE Fanuc 90-30. We've got one , and an old XP laptop , with a converter cable, and ECLiPS . We...
2,910
Is there any documentation on GE FANUC SNP protocol with source codes and possibilites to read and write data on Versamax? Modbus is very limited...
1,577
I'm trying to establish snp serial communication between GE Fanuc CPM-790 programmers port ( 15-pin, RS-485) using 4-wire connection. On the PC...
3,202
Greetings List.. I'm a real newbie to PLCs and having trouble deciphering what software to use to communicate with and probably modify a program...
13,243
I’ve written a SNPX driver for our products. The SNPX has been easy to integrate. The next issue I have is when I read in an analog input; I...
2,261
