I'm trying to establish snp serial communication between GE Fanuc CPM-790 programmers port ( 15-pin, RS-485) using 4-wire connection. On the PC end I'm having a RS-232/RS-485 to Ethernet Converter ( Make MOXA).
The pinout of MOXA RJ-45 is: (MOXA is connected to PC on Ethernet)
PIN----RS232----RS485(4W)/RS422----RS485(2W)
1------DCD-------------TxD-(A)
2------RxD-------------TxD+(B)
3------TxD-------------RxD+(B)---------- DATA+(B)
4------DTR -------------RxD-(A)------------DATA-(A)
5------GND-------------GND------------------GND
6------DSR
7------RTS
8------CTS
The pinout of CPM-790 (Programmer port) DB15 is:
PIN----DETAIL------------ JUMPER
7----- SG-------JUMP [PIN- 9 (RT) TO PIN-10 (RD (A')]
10-----RD(A')-- JUMP [ PIN-8 (CTS(B') TO PIN-14 (RTS(B) ]
11-----RD(B')---JUMP [ PIN-6 (RTS(A) TO PIN-15 (CTS(A') ]
12-----SD(A)
13---- SD(B)
In PC Moxa is creating virtual RS-485 com ports, so I’m connecting 4 wires ( & GND) directly to MOXA’s Com Port. ( Is it required to convert RS-485 to RS-232 in this case, because MOXA is not converting RS-485 to RS-232 ?).
Any help would be much appreciated!
6------DSR
7------RTS
8------CTS
12-----SD(A)
13---- SD(B)
