GE Fanuc Versamax HSC ComReqs
BarryP
Jul 2003
Perth Western Australia
Has anyone any examples of using the Comreqs of this PLC for changing the value of a B Type HSC to zero on command, e.g. when %M100 goes high.
The PLC is a IC200UAL006-AA version & I am using Versapro Vs2.01.
I already have the manual on this unit but the write-up is very inexplicit and a bit wishy washy.
Thanx in anticipation
Have you checked the GE-Fanuc website and done a search? I have found some excellent examples there for other things before.
beerchug
In the example on page 12-18 of GFK-1645C, for your case, the value at IN4 of the second Block Move instructon should be 0101(hex) and the value at IN5 should be zero.
If you use different %R registers than the example, the value at IN3 will need to change. It represents the the address offset of the register that contains the command word. In the example, that register is %R111, thus the value 006E (hex), or 110 (dec).
I have one GE Fanuc IC200PNS002-AC Versamax Network Interface Module and the fault red light is blinking and i have checked in manual it is...
222
Hi. I have an Ge Fanuc Controller versa max and need to know where i can download the software for this PLC, anyone that can direct me please. I...
1,213
Hello, This is probably an easy question—or at least I hope it is—and it will show how green I am. I've been tasked with troubleshooting a GE...
3,274
Every time i turn off and turn on the PLC, PLC is not going to RUN mode In the fault table it shows error " system Configuration mismatch" And...
1,760
Hi everyone! There's an old GE Fanuc Versamax that I don't know how much longer will it keep working, so I decided that it is time for a change...
1,401
