ge fanuc
jaichains
Jul 2005
Rotherham
46
Hi
Could anyone tell me difference between ifix, cimplicity and intellution? what is intellution and what is the history of intellution, when did it join GE fanuc. Thx.
Well from what I remember of it, Intellution was a company that developed a SCADA package called Fix, I used Fix v6,v7,v8, after that came Fix32, that was in about 2000 and used a 32 bit program base, after that came iFixand that's when GE bought them out. They were bought out in mid to late 2002 and stopped supporting Fix vXX but still supported Fix32 and iFix, from what I understand at this point they're up to iFix v3.5 and are calling it Proficy. The original iFix seemed to me be a little a little clunky in some areas but they were very good at handling tags and setting up security. I was only on 1 project that used Intellution but the monster drug on so long that we used 5 different versions before it was done. Now remember this was almost 3 years ago and I'm an instrumentation startup tech not a SCADA programer so my recollections may be a little off, but I do remember that GE bought up intellution before we were finished with the project in 2002 and between 2001 and 2002 we converted the SCADA from Fix32 to iFix and the engineer and I had to rebuild some of it because the original pages had been built in Fix v6 and converted from there.
[font=Arial, Helvetica, sans-serif]Greetings jaichains,[/font]
You may find some answers here:
FAQs & Industry Views: Intellution & GE Fanuc
[font=Arial, Helvetica, sans-serif]Q. Why did GE Fanuc buy Intellution? [/font]
[font=Arial, Helvetica, sans-serif]A. Intellution has excellent products and technology, and a large and diverse customer base, including a global sales channel. Intellution has a long record of delivering outstanding, business-enhancing solutions to its customers. The addition of Intellution to the GE Fanuc family provides a powerful combined offering of software and solutions, including batch, electronic work instruction, plant-wide data historian, HMI/SCADA, enterprise and remote asset management, analytics and collaborative production management. Bringing Intellution into the GE Fanuc family supports GE's ability to deliver world-class solutions that improve quality, reduce cycle times, increase profitability, and facilitate collaboration in the supply chain…driving a competitive advantage. [/font]
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
50
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
133
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
125
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
119
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
191
