Ge historian system scheduler
I got your PM of the same question. I don't mind PM but please send a link to your post here. The idea of the forum is for everyone to discuss and learn.
Regarding your question. "GE historian" isn't useful, GE have used many different version of historians and none of them are able to send out email notification except for the PI historian but that isn't really a GE product but GE does bundle it with their Turbine DCS system. So, please be specific on what product and version.
From your PM,
IFIX version 5.8
The historian version is 5.0.195.0
The OPC is IFIX CLIENT VERSION 7.46
It always try to send the report to the various email assigned to it , but the mail never gets send.
I'm going to make a few assumptions which may or may not be correct. One is that the historian is actually the Proficy Historian and the OPC driver is IGS driver.
I have used Proficy historian but I'm unaware of its notification ability. So I can't help yo specifically with that. However, email all work the same way. You need to have an email-client, in this case the historian that talks to an email-server.
I would try another email-client to send out test email to see if the problem is just communication to the email server first. If that works, then you focus on the historian.
I noticed that the new FTHistorian 9 only uses the PI 2018 still, and is not updated to 2023 yet. I figured by now any new releases would have...
78
We are a water/wastewater plant, collecting realtime and manually entered data. We have been using FactoryTalk Historian (OSI PI) for real time...
139
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
50
Hello Everyone, I want to install and configure factorytalk Historian v6. I'm new to this. Can you kindly share some knowledge on installing...
80
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
179
