GE IFIX Old backup to 5.8 conversion.
Shiro485
Apr 2013
North Haven CT
103
Hello,
I am doing a project in which a system was designed with an older version of Ifix and the backupfiles are being moved to version 5.8 for a new version of that system.
I seem to have gotten everything over and working properly but I am having issue with sql database stuff they where using before. I have restored the sql backup file installed sql server, created an odbc driver. I have verified with mission control in ifix that it is connected to the sql database.
When launching a picture in run mode that is dependent on that database I get Compile Error: Sub or function not defined.
It highlights where it looks like it calls the components of that database, starting with the database name, which is RTP. It appears like they are not defined somehow?
I have attached a couple of screen captures, if anyone is able to point me in the right direction I would appreciate it very much.
Thanks and Happy Holidays
Brian
Maybe there was a global VB module with this function, which got lost on project conversion.
Had the same problem with another module which got lost on update from iFix 3 to 5.8. I've started the old project, exported the module as plain text, and added this as new module it to the new project.
46
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
162
169
Hi everyone. I'm beginner with Ifix. I'm appreciate if you share me some document to understand how to play with Ifix 6.0. By the way, I have some...
732
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
461
