GE PLC - Warning 12539: Memory area has associated value(s)
paramesium
Nov 2014
Malaysia
Hi all,
I was working on a GE PLC, and I happened to get the following warning:
Warning 12539: Memory area has associated value(s) [%I]
May I know what will be the possible reasons that make this happen?
Please advice, thank you.
Here is what Proficy Machine edition has to say about that warning:
Warning 12539: Memory area has unassociated value(s) [%[memory area]]
During an upload from a PACSystems, a non-zero initial value was found in the memory area mentioned in the Feedback Zone, but no variable is mapped to that memory location. No variable is being created in Logic Developer - PLC to contain that value. If you are using initial value data tables, that non-zero initial value is not uploaded to a table.
Example
A memory range has been defined for a module status, but no variable has been defined to refer to that memory range.
I know that you should not use a non-safety rated PLC for safety applications, but I was wondering if anyone saw anything wrong with the...
3,455
Since upgrading to RSLogix 5 V6.00.00 we are getting a message everytime we go online that a PLC Firmware crash log has been found in the...
4,627
33
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
64
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
44
