GE Proficy Question
Tweeker
Nov 2007
Smalltown
79
I am following some other engineers who have left the company and I needed to install the Proficy software (Ver. 6.0) on my PC. I have the software up and running but for the life of me I cannot find out how to import projects from another PC or projects backed up on our server.
Right click on any project in the navigator window and select "Back Up".
If you are starting from a brand new first-time installation of Proficy, there won't be any projects in the navigator window unless you chose to install the sample projects. You will need to find where the projects from other Proficy installs have been saved. If you are looking on another computer that already has Proficy installed, the default location for backup files is C:\Program Files(x86)\Proficy\Proficy Machine Edition\Backup
If you are looking for the backups on a company server that doesn't have Proficy installed, its anybody's guess where they are.
See attached pic Why is R02451 reading 0 before the Real_to_Int conversion? It is reading 23 after, which is what it should read.
1,669
Hi All, I'm fairly new to Proficy and perhaps the problem is that I'm trying to get it to do some of the same things I'm used to doing with...
3,211
hi I want to use proficy inside c toolkit function but It asked me to choose a .geflf file How can i produce this file? What is...
1,915
hi I have a proficy program I want it to prevent others from peeking or copying inside the content I use my own function and set my password,But...
2,986
I'm pretty much brand new in the plc world and i'm struggling a little bit. I recently took a "hands-on" test for a possible promotion at my job...
2,856
