proficy software question
morty
Feb 2017
taiwan
hi
I have a proficy program
I want it to prevent others from peeking or copying inside the content
I use my own function and set my password,But I found that as long as you copy the entire file
And used in another, even if others do not know the password, but the same can use my project
reference document:GFK2222W_PACSystems_RX3i_Rx7i_CPU_Ref_Manual
4.9 System Security
Software version:V8.6
How do i prevent someone from stealing my program?
Put an "OEM" password on your project.
With this, even if they put it into another CPU it would be nearly impossible to get it to run properly on any hardware configuration and wiring scheme other than yours.
Deal with a better class of customers.
Seriously, I've been in this business long enough to have come to the conclusion that passwords are only a deterrent to honest people. If you only sell your product to honest people, you won't really have to worry about piracy, regardless of whether or not you apply a password.
Furthermore, I would never consider buying a machine from you if you protected the PLC program such that I could not modify it if I saw the need to.
Hi All, How do I set a password to PLC using Proficy machine software 9.5-9.8 or some other way? I as using Emerson CPE305 CPU. Thanks.
363
I m installing GE Proficy Change Management Software at site. We use GE Fanuc PLC's on firld equipment. But the process plant is changing to...
5,939
Hi, I developed the project for the GE 90-30 kit using proficy machine edition but my end client do not have proficy machine edition. They have...
6,629
Version 6.0, QuickPanel HMI 14", GE Processor, ethernet I am an A-B guy so I am not very experienced yet on GE. The vendor refuses to turn over...
3,083
I've had limited exposure to GE PLC's. The Logic Master programs seemed to be intuitive. We now have a new system of 90-30 and 90-70 plcs and...
17,823
